Results 1 to 2 of 2
Thread: Beko cda543fw fridge freezer
07-02-2017, 04:28 PM #1
The fridge in my beko cda543fw is running at -2c I,ve changed the control board on the back of the fridge and the potentiometer board in the fridge as recommended on the net but it,s still freezing up .
There must be a dodgy sensor but I can only think it must be foamed in at the back of the fridge does anyone know and where I can get a replacement, Ive been on to beko but they just want to send an engineer!
08-02-2017, 07:52 AM #2
Re: Beko cda543fw fridge freezer
Not familiar with Beko. It is likely a Damper issue if fridge section relies on air from the Freezer.
PC controlled damper may be damaged. Mechanical failure.To the optimist, the glass is half full. To the pessimist, the glass is half empty.
