Thread: gear bender
13-05-2006, 09:19 AM #1
gear bender
Hi all
Has anyone else had any problems with imperial eastman 1"1/8 gear benders. The pinion cog part which the handles go through keeps losing its teeth. I'm on my third one now, my bender is due to go out of warranty and the part costs around £50.00 to replace.
I've been using these benders for about 10 years now and this has never happened before.I would like to contact the manufacturer for some help but can't find their website, perhaps they have changed the type of metal.
13-05-2006, 10:08 AM #2
Re: gear bender
Originally Posted by freezy
http://www.imperialeastman.com/
Eastman is a very reputable make and has been making good equipment for many decades.
If it has suddenly started happening on previously reliable tools, have you considered the changes lately to copper tube manufacture with the introduction of the PED in Europe?
Wall thicknesses and possibly tensile strength of the metal has increased due to the adoption of R 410A in recent years.
It may be a long shot, but worth considering.
________
top penny stocksLast edited by Argus; 07-02-2011 at 10:09 AM.
13-05-2006, 08:32 PM #3
Re: gear bender
mines a few years old now and no probs,may be cheaper made and cheaper pipe !
22-07-2006, 02:13 PM #4
Re: gear bender
I always put the benders in a b&d work bench, oil the bender surfaces & lightly heat area to be bent otherwise they are a nightmare to use
19-08-2006, 07:42 PM #5
Re: gear bender
I have been using these for years also and have broken 2 or 3. Tends to be general wear and tear, plus some manufacturers\suppliers use thicker wall copper. Sounds dodgy to have done so many in such as short space of time. Perhaps its the copper you have been using. Try oiling them daily.
Steve
22-10-2006, 05:03 PM #6
Re: gear bender
I've had to spray the pipe with something like WD-40 for the gear benders to work easily and effectively.
I went to a REMS ratchet a few years back and my gears went into retirement.
Tube bender
By klimek in forum Tools and CalculatorsReplies: 1Last Post: 12-02-2005, 02:34 PM
