    Jan 2017
    Saudi Arabia
    29
    1
    Doule Jacketed tanks
    Hello
    I need a formula to calculate the Ton refrigerant to cool down some liquid from 22 c to 10 c in a double jacketed tank. The cooling media is water. I need to calculate the chiller capacity needed for this process.
    Sep 2003
    ISRAEL
    66
    4,120
    38
    Re: Doule Jacketed tanks
    Welcome to the forum Omar.
    To be able to calculate' please add a few parameters:
    - What is the mass? kg, ton?
    - Area of heat exchanging? sq/m.
    - insulation? Thickness and material.
    - No. of cooling circuits?
    The more details you supply [pictures are always helpful] the easiest it will be to help you.
    Sep 2009
    Iran
    469
    12
    HI
    There is a lot of quition
    How much you need cool
    With whicth temp you want to rich to that
    What is you pump flow rates
    What is you tansfar heat area
    What is the insulation out of tanks
    What is the room temp.
    Q=MC(T2-T1)
