Results 1 to 15 of 15
    Jan 2017
    usa
    5
    vehicel a/c not getting cold
    I have a vehicle which the a/c (134a) is not going below 70f. Outside temp 85f. Low side pressure 30 to 35 psi high side 185 psi. I believe thermostatic expansion valve is work (its new)because I see the pressure will hold at 30 then move to 35 psi then a few minutes latter it will return to 30, high side changes accordingly with low side.
    The discharge of the expansion valve is a little cold to the touch.
    Is the expansion valve out of adjustment? if so would I increase pressure on the spring (turning counterclockwise) or decrease the pressure (turning clockwise)?
    to adjust it I have to remove it. Right now the system is void of 134a.
    Feb 2007
    2,473
    Re: vehicel a/c not getting cold
    Quote Originally Posted by cebudave View Post
    Most likely you got an issue with the amount of refrigerant in your system. The way forward is to ensure you get the system to a deep, standing, vacuum (<3Torr) and then recharge the system with virgin 134a, weighing it in according to the manufacturer's specification.
    Sep 2003
    ISRAEL
    72
    4,248
    And make sure all heating pipes are closed.
    Dec 2010
    devon
    837
    What is vehicle.and age
    Jan 2017
    usa
    5
    Quote Originally Posted by charlie patt View Post
    its a 1992 Suzuki every van, the pump, drier, and expansion valve are new. flushed the whole system also.
    I was thinking the expansion valve is out of adjustment
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    No mention of Evaporator cleaning or replacement. A New Factory set vehicle expansion Valve rarely need any tinkering.
    Over in OZ, a 20+ year old Evap is past it's use by date.
    Suction pressures mean bugger-all unless a specific Engine RPM is included.
    Loss of Gas is one possibility.
    Dec 2008
    564
    Check that the evaporator fan motor is running at the correct speed and that the fan blade is not dirty causing a reduced airflow.
    Dec 2010
    devon
    837
    At that age first thing is
    1, is it on the correct gas on 1992 could be on 12
    Also lot more info please firstly is it fixed speed or fan speed controll condensor fan
    Has the system been hp tested overnight to prove system held pressure vacing and holding a vac not good enough
    If system been flushed what amount of oil been installed
    and is it single or twin evaporator when you say van ie commercial or people carrier sorry but in devon van to us is a commercial vechicles
    On system like this you have to start from the beginning otherwise u end up going around in circles my issue is slightly high low side and at that ambient not enough head ta charlie
    Aug 2009
    12
    Quote Originally Posted by chemi-cool View Post
    I agree! If the unit is charged to specs., check your heating water system for unwanted heat leakage air mixing. Your vehicle may or may not have a hot water hose shutoff valve, but may have a supply air mixing door instead.
    Jan 2017
    usa
    5
    Ok two years ago I changed the pump from r12 to a r134a one, r12 pump no longer available. After which the system was flushed with denatured alcohol, dryer changed, expansion valve, and recharged with r134a.
    Right now its 40 psi and 250 psi, temp 70F, this is at idle 900 rpms. All fans ae working properly.
    Question is if I screw the hex screw in it should increase the flow into the evaporator? thus lowering the superheat.
    Dec 2010
    devon
    837
    On provision u have the correct level of refrigerant ,,,,on that age in uk we would have a sight glass and 900 rpm your suction pressure is to high if needle on gauges not flickering I would suggest oil charge incorrect or bad pumping comp this is on condition gas level correct if you bring you revs up to 1250 partly cover condensor with cloth sea what suction is if head rises slightly suction stays same comp poor or bad oil level 12 and 134 valve ni on identical but at high ambient they suffer screwing the valve will do little but they do have a sive before them if the valve body icing on comp side this indicates this but this normally covers low suction also is there any sweating on suction line I pressume gas level been checked recently????
    Jan 2017
    usa
    5
    Ok, I just took the following pressures and temps Low 40 psi, charts says that's 45*, outlet pipe to evap 80*, High 200 psi, chart temp 130*, inlet pipe to expansion valve 102*
    Outside temp 85*. vent temp 58*. engine rpm 900
    superheat P/T 45* minis 80* = 35*
    subcool P/T 130* minis 102* =28*
    Sight glass on drier looks foamy
    Now the whole system was flushed, and blown out with air. Vacuumed system to 28 hg held over night
    Replaced drier, expansion valve, and condenser fan with a higher cfm (fixed speed)
    So do I need to open the expansion valve a turn out to allow more flow into the evaporator? Or is there some other thing I am missing. Any help would be appreciated.
    Dec 2010
    devon
    837
    As previous your suction is to high your head to low if you have a higher speed fan at 900 rpm engine revs your short 50 psi head and suction 10 psi to high sight glass should be clear at this ambient you should be running 250 min with high speed fan most systems will hold a vac holding pressure on cars is a different thing before playing with tev u really need to check gas level your sight glass is active because it's short or something in system that should not be or oil the biggest problem is most of the above work is just worrying who flushes then blows out with air then replaces tev, also fitting higher speed fixed fan on a car is silly most have variable speeds to allow air flow when driving only ones that don't is subcooled units which this is to old I think you just need to start from basics a basic car ac is simple but if you alter parameters and you don't no what you are doing you just make it worse the biggest problem you may well get it correct on idle then you take it up the road and due to engine speed and airflow vechicles ac don't work
    Jan 2017
    usa
    5
    Ok, so what should the low psi be at idle? The drier, where the sight glass is, is before the TEV on the high psi side. From my understanding the r134a at that point is to be 75% liquid and 25% gas, or am I wrong regarding this.
    Could you give me the following info, ball park figures would be fine.
    Low side PSI -
    outlet temp evaporator -
    High side PSI -
    Inlet temp to TEV -
    This a Suzuki super carry van. the condenser is underneath the vehicle, not in front of the radiator. The stock fan was a single speed fan. It was pulling too many amps, that's why I replaced it and the radiator fan.
    Feb 2009
    telford
    2,090
    33
    I would take the evaporator out the condensor out and remove the oil from them of course refit them fit a 134a valve another new drier drain the compressor oil and refill it with the oil for 134a pressure test vacuum the system and recharge with 134a to the manufacturers specification,after all that it should work and the aircon repair will be worth more than the vehicle!!!
