Results 1 to 50 of 77
Thread: Propylene System
Threaded View
11-12-2010, 02:51 PM #37
Re: Propylene System
Yes. There are two parallel oil filters in the oil system. The oil filte is similar with ***** application. But there are a bit difference that the rubber material ( O ring or sealing ) is HNBR suitable with PAG. The cartridge is fabric about 20um filter efficiency.
The filter body is carbon steel.Last edited by sagittarius; 11-12-2010 at 02:55 PM.
Daikin fault codes
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
