    May 2006
    Las Vegas, Nevada USA
    12
    Pressure to Temperature Conversion
    I have found online calculators for water/vapor pressure, and temperature to pressure conversion calculators. However, I need to find out what the temperature of Water/Vapor will be at a specific pressure.
    Does anyone know of an online conversion calculator for Pressure to Temperature?
    Aug 2005
    5,327
    Re: Pressure to Temperature Conversion
    Joe,
    Is this what you are looking for?
    If it is, let me know and I can convert the pressure units or temperature into the units desired.
    Or, I can provide the curve fit equation if this would be more helpful.
    Attached Files Attached Files
    May 2006
    12
    Looks good.
    Let me ask, if I have the following data:
    889.25 mmHg (17.198 psi) at 104.4 ºC - (220ºF)
    for a 1/2" copper pipe and I drop the pressure by increasing the pipe dimension to 1", 2", 3"...etc... would my pressure drop by half each time? If not, at what rate can I expect a pressure drop (percentage) 25%, 10% etc...
    I hope my question clearer than mud.
    Speaking of mud, do you recall that guy from Thailand asking questions about making an air conditioner from a refrigerator?
    Well, if all goes well with this project, it would be a portion of a passive solar cooling unit that would work very as well in the tropics as it would in the Las Vegas desert.
    Joepompous's Avatar
    Joepompous Guest
    I am looking for what temperature in degrees fahrenheit would a fixed volume of gas need to be heated to in order to double its pressure if it starts out at 25 degrees fahrenheit
    Oct 2008
    mallorca, spain,
    69
    771
    13
    hi jo , what type of gas and is it just vapour or is there any liquid gas apparent ?
    Aug 2009
    New Zealand
    54
    2,556
    Quote Originally Posted by Joepompous View Post
    Thinking back to my school days (Eve was my teacher and Adam was the head master)
    If "V" is constant then
    p1t1=p2t2 (boyles law i think?, but I think not?)
  1. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  2. This a long one - AKV
    By Peter_1 in forum Industrial
    Last Post: 26-12-2008, 11:47 AM
  3. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  4. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
