11-05-2006, 08:06 PM #1
Heat Recovery for Air Conditioning
Hello,
Ive been given an assignment in college on Heat Recovery systems. Ive done most of the assignment but to complete it could someone help me with the last couple of questions.
What problems could arise if the systems are not set up properly?
What factors can be affected by a failure to provide adequate maintenance?
The systems Ive chosen are Heat Pipes,
Run around systems and Heat Wheels.
Any help would be much appreciated
Stu Eng
11-05-2006, 09:02 PM #2
Re: Heat Recovery for Air Conditioning
This is new... what is a run around system? By heat wheel you mean rotative recovery?
11-05-2006, 09:34 PM #3
Unless the student is describing something else, a run around system is a pumped glycol system between two heat exchangers.
Another item to look at for heat recovery is using a thermosiphon system with two heat exchangers. Works very nice.
11-05-2006, 10:29 PM #4
Originally Posted by Student Eng
Inadequate maintenance can cause all sorts of problems depending on the equipment requirements. Think of it like a car, if you drive it for long enough without checking or changing the oil then the engine will suffer. Eventually it will fail. Now you can't blame the engine for giving up can you?Brian - Newton Abbot, Devon, UK
13-05-2006, 08:23 AM #5
Thanks for all your help
Student Engineer
13-05-2006, 05:28 PM #6
Hi Student eng,
Heat recovery systems are used for 100% fresh air air conditioning systems.
It basically utilises the lower temperature or exhaust air compared to incoming fresh air.
There are two types of heat recovery wheels
1. Heat pipes : These can provide sensible heat recovery however latent heat recovery capacity of heat pipes is limited.
2. Enthalpy wheels: Enthalpy wheels provide maximum heat recovery efficiency of 75% both sensible and latent.
Suppose the heat recovery does not function then the capacity of cooling coil will be much less to cool the entire fresh air. This will lead to an increase in inside room temperature and relative humidity.
There are a lot of things that can go haywire in case proper maintenance is not provided.
Utimately the customer should get the design temperature and humidity. Therefore, maintenance should be proper.
RegardsVijay Kumar
HVAC Design Engineer
BMCPL
"The more you sweat in peace less you bleed in war"
frostles heat pump
plate exchanger in heat recovery ventilator
By Lc_shi in forum New TechnologiesReplies: 1Last Post: 17-07-2007, 04:30 PM -
Heat recovery and aquifer heat/cold storage
By RicHoe in forum Supermarket RefrigerationReplies: 23Last Post: 23-06-2006, 01:24 AM -
heat recovery systems
By Brutalic in forum Supermarket RefrigerationReplies: 5Last Post: 19-05-2006, 01:01 AM -
Remote condenser + heat recovery
By Renato RR in forum Technical SpeculationsReplies: 9Last Post: 30-03-2006, 07:26 AM
