    Nov 2016
    United Kingdom
    2
    Candy fridge Icing
    Hello all,
    I have a Candy CBCA260uk 50/50 fridge freezer , the freezer works ok but the fridge is icing up ,
    I have tried switching it off for 24hrs , also on different temp settings and checked the door seal but it keeps freezing.
    I have tried searching but I have probably confused myself !!
    I have found a fridge thermostat if needed .
    Many thanks in advance Paul
    Oct 2001
    Nottingham UK
    5,128
    42
    Re: Candy fridge Icing
    More than likely the flap between the fridge and freezer is iced open.
    Try at least a 48 hour defrost with the doors open
    I'm back on the Pale
    Nov 2016
    United Kingdom
    2
    Hi thanks for the reply ,
    I will have to arrange storage then i will try it .
    Thanks again for the help will let you know how it went . Paul
