    Nov 2016
    43
    2
    Parameters of SAnyo RCS-TM80BG
    Hello all,
    I have a question regarding SANYO control panel and outdoor unit :
    During normal operation for heating, the outdoor unit has 2 or 3 different 'speed' of compressor/fans.
    Is it possible to force the outdoor unit to the low 'speed' ? Via a parameter set on the control panel ?
    I measured the current of the outdoor unit, and I had a first step at 8A, after some minutes, it switch to 13A and then max measured at 18A.
    For several reasons, I would like to limit the current at 8A.
    Thanks for your help.
    Manu.
    70
    10,682
    52
    Re: Parameters of SAnyo RCS-TM80BG
    You have quoted the reference model number of the remote controller, we need to know the model number for the indoor and mostly the outdoor unit.
    Nov 2016
    43
    2
    Hello, thanks of your reply.
    The outdoor model is a Winverter 484 from Airpac (climastar). But It is a Sanyo 42,000 BTU with 2 fans.
    Indoor unit is a specific unit from Airpac to use it as a Heating Pump Air/water. The indoor unit has a similar control card than indoor units for cooling.
    Hope it can help you...
    Thanks.
Tags for this Thread
