Results 1 to 2 of 2
Thread: 30S carrier
23-11-2016, 08:42 PM #1
30S carrier
I just brought a 30s carrier truck with Reefer and it has a code A02? How can I fix it
24-11-2016, 12:06 AM #2
Re: 30S carrier
That code is high refrigerant pressure,more than likely the condensor fan motor brushes have worn out,the condensor is the part on the outside of the vehicle/box you have to remove the plastic cover to gain access and sometimes removing the fan blade then the motor is the easiest way disconnect the battery first!
