14-11-2016, 12:45 AM #1
Correct cooling temps and pressure readings for different refrigerants
Hey guys
Has any one gt a air on/off temp range for each refrigerant, and working pressure range??
I am training as a fault finding engineer and would be very helpful when checking a/c if i new if the unit is working at correct temps and pressures or if i need further investigation into the unit.
Thanks all
14-11-2016, 02:54 AM #2
Re: Correct cooling temps and pressure readings for different refrigerants
down load the Danfoss pressure temp slide rule APP to your mobile phone from danfoss web site.
14-11-2016, 08:03 AM #3
Daniel,
This is a good link although not answering your question exactly, as it is not always clear cut.
http://www.refrigeration-engineer.co...rigeration-101
14-11-2016, 12:04 PM #4
Nice read mate, very imformative .
