Thread: Beko cs460ffw
    May 2006
    ENGLAND
    109
    12
    Beko cs460ffw
    I have a Beko Fridge Freezer that just keeps running. Seems to be cooling ok. Ihave fitted a new stat but just the same any ideas please
    Oct 2001
    Nottingham UK
    5,086
    42
    Re: Beko cs460ffw
    Quote Originally Posted by SKOOBY View Post
    Any technical data to confirm this or is it just a guess?
    I'm back on the Pale
    Apr 2008
    Southampton, England
    43
    895
    27
    Re: Beko cs460ffw
    Control PCB somewhere and compressor relay is stuck on.
    Don't do much on domestic stuff so just a guess.
    Cheers,
    Andy.
    Nov 2010
    wales
    9
    Re: Beko cs460ffw
    Seeing as you have already changed the thermostat, try removing one lead to the stat and see if comp still runs, if it does Tayters is right. Also make sure end of stat capillary tube is in right place and secure. Best of luck and be safe.
