    Nov 2016
    1
    Door Frame Heater regulation
    Does anybody know if there is a legal regulation for the temperature of a door frame heater? on a freezer cabinet.
    Feb 2006
    Hampshire
    61
    Re: Door Frame Heater regulation
    Not as far as I'm aware.
    You take the total length and decide if you want l / m / h temp and wire into the transformer as necessary.
    May 2012
    59
    1,537
    The resistor wire will give a fairly constant heat
    given the correct voltage input so they are fixed
    as far as I know.
    Warmer than freezing but not too hot to burn
    That last bit might not have helped
    Rob
    Sep 2003
    ISRAEL
    72
    4,266
    The job of door frame heater is mainly to prevent the rubber seal from getting stuck to the frame and to keep the bottom free of ice and stop humidity entering the cold room.
    Depends on the cold room temp, we use 25w\m to 40w\m heater stripes.
