Results 1 to 9 of 9
    Mar 2007
    Egypt
    49
    43
    Need advise in overhaul for Frick 283L compressor
    Dear my friends
    I need your advise in over haul for compressor frick 283L when I check the discharge clearance I found it 0.27 mm for male 0.26 mm for female without any shims . the recommended clearance is 0.22 mm for both . I have tow Options one of them scrape off 0.05 from inner bearing for thurst ball bearing the scuond option put 0.05 shim before outer rining for thurst ball bearing . the quatetion which one is correct ? I need your advises.
    Thank you
    2,578
    29
    Re: Need advise in overhaul for Frick 283L compressor
    Quote Originally Posted by dolce View Post
    Dear my friends
    Thank you
    dolce,
    Either way is OK , I personally would grind inner spacer to get clearance.
    If grinding or lapping spacer has to be perfectly parallel.
    It could be done by hand on lapping plate with coarse sanding paper.
    Manual says 0.2 to 0.28mm discharge end clearance & use 0.23 as example to aim for, so current clearance maybe OK, but maximum.
    Make sure main bearing inner races are definately on all the way,check with feeler gauge &/or hydraulic jacking tool.
    Mar 2007
    Egypt
    49
    43
    dolce,
    Thank you Ranger l am very happy for your reply today l try to adjust the male clearance it was 0.27mm after I put a shim 0.05mm at outer bearing I get clearance 0.2 . I think it is ok in range but by calculate I must get 0.22mm .I don't know why do I get 0.2mm
    2,578
    29
    Also check bearing play as per manual to make sure it corresponds.
    0.2 mm is OK for DEC.
    Mar 2007
    Egypt
    49
    43
    Dear Ranger
    I Installed the female and check discharge clearance found it 0.19mm for male 0.20mm .Now is the female clearance is Ok all though the Factory recommended range is 0.2 mm to 0.25 mm
    best regards.
    Mar 2007
    Egypt
    49
    43
    Dear Ranger
    best regards.
    By the way the bearing play is 200 um (0.02mm)
    Jul 2007
    Czech
    55
    338
    13
    Hey, you want Frick 283 clearance of 0.20 mm? is your choice, I personally 0.25 to 0.28 millimeters, has worked for many overhaul but the idea of suicide is 0.20 mm.
    2,578
    29
    dolce,
    Agree with Josef & you will find old manual has changed to now recommend larger end clearance.
    Old clearance 0.2 to 0.254mm
    now is 0.2 to 0.28mm
    Bearing play is 0.0254 to 0.14mm, so you bearing play is also below minimum
    0.19mm end clearance to small, start again & leave clearances as you first measured.
    Mar 2007
    Egypt
    49
    43
    Many thanks for your advice support
    Really I have old version of manual for 283 frick compressor
    Could you please send me a new version of manual if you have?
    Best regards
