    Nov 2016
    Ireland
    28
    3
    Post Thermostat deadband
    Explanation of this in the least scientific jargon free way possible?
    Many appreciations
    B
    70
    10,600
    52
    Re: Thermostat deadband
    Okay....
    Assume we are trying to cool.
    Set point = 20C
    Temperature rises to 21C, cooler switched on.
    Temperature drops to 19C, cooler switches off.
    21 - 19 = 2K
    Therefore deadband is 2K; the temperature needs to change by 2K before anything happens.
    Auckland
    68
    3,362
    32
    Air conditioning controllers have an effective dead band, in between heat cycle differential and the cooling cycle differential. So when in dead band neither heating or cooling is activated, dead band could be around 2> 3 degrees C
    Jul 2010
    NTH.QLD Australia
    56
    1,757
    26
    I can see OP questioning Degrees K Brian.
    So 21 degrees C - 19 degrees C = 2 degrees C deadband. ( or 2 degrees on the Kelvin scale.)
    70
    10,600
    52
    True, thanks Mike
