Results 1 to 8 of 8
    Oct 2016
    United Kingdom
    30
    2
    Question Daikin Althelma HT 11kW
    Hi everyone,
    I would like to ask you about the heating capacacity table of the Daikin Althelma HT. This kind of heat pump is cascade technology and can lift the outlet temperature up to 80 Celcius. I see in the table that the rated capacity is constant while the rated power changes according to set of conditions. Would anybody can explain the reasons for it? Also, in the table, is this the data for the whole system rather than for only outdoor unit (I misunderstanding because this kind of heat pump contains two seperate heat pump units, indoor and outdoor)?
    P/S: please access to the link if you want to get the data of the heat pump
    https://drive.google.com/file/d/0B3L...BKZ25SUE0/view
    Thank you very much!
    70
    10,627
    52
    Re: Daikin Althelma HT 11kW
    Your link is private, none accessible.
    The power can change due to the varying enthalpy of the ambient conditions.
    Oct 2016
    United Kingdom
    30
    2
    Hi Brian,
    Sorry you. I just reset the public link.
    Thanks.
    70
    10,627
    52
    Should have added that it is a single compressor, not a cascade system.
    Oct 2001
    Nottingham UK
    5,127
    42
    Not so Brian
    The Daikin HT Altherma has 2 refrigeration circuits. The outdoor compressor is on r410a and the indoor compressor is on R134a.
    I'm back on the Pale
    70
    10,627
    52
    Not so Brian
    oh, okay, thanks Frank.
    Nov 2016
    Việt Nam
    1
    Thank you for your very useful information.
    May 2010
    2
    Just a quick tip on Altherma:
    Anything with HT in the model is High Temperature(uses small R134a cascade set up)
    Anything with LT in the model is Low Temperature ​(Standard R410a 'split')
