Results 1 to 2 of 2
    Oct 2016
    ireland
    1
    Daiken E7 fault. model:erhq014aav3
    I have had the above model for 8 years.
    Last year i had to change the compressor.
    Now the outdoor doesn't come on at all. Fault code e7 showed on the screen once.
    Power is going to the unit with a green flashing light on th pcb. i cant see the red light on h1p.
    see pics
    Is this a faulty control pcb?? is there anything else i can try.
    Jun 2016
    Bulgaria
    33
    1
    Re: Daiken E7 fault. model:erhq014aav3
    The fault e7 means that there's something wrong with your fans.Screenshot_2016-11-05-18-52-49.jpg. Maybe it is drawing to much current and it protecting the system from blowing. Check the fuses in the pcb.
