Results 1 to 11 of 11
Thread: "Nuts"
    May 2012
    1,264
    28
    "Nuts"
    Yes nuts................................
    I'm after stainless steel fittings?
    I need 1/2" to 1/4" male to male reducers and
    I need 1/2" male plugs..
    Are they made in Stainless? and if so does anybody know where
    I can get some? I only need about 20 each and they are for testing.
    Continuous connecting, releasing and pressure testing soon wears the
    brass ones so I'm after something more beefy.
    Rob
    Feb 2007
    2,477
    Re: "Nuts"
    Try www.customfittings.com
    Used them a couple of times in the past and they usually got what's needed in stock.
    Somerset
    63
    4,529
    38
    Re: "Nuts"
    Hi Rob.
    Someone somewhere makes Steel fridge fittings.
    But the nearest I have got in the past for use on ammonia plant.
    Is to go to your nearest trusted Hydraulic Suppliers.
    Armed with a pair of 1/2 " and 1/4" fittings to be used as templates.
    Because they sell JIC fittings which work fine as male to Fridge female.
    The flare angle is slightly sharper and the thread turns are less.
    I know that a 1/4" flare is called a 3/16" JIC.
    so 1/2 " would be known as a slightly bigger imperial size.
    Check it out I have been using the for 25 - 30yrs.
    With no Issues.
    J&E Hall used to have some Flare fittings but most were Wade fittings.
    If you do find where to get actual flare fittings please share as they would be a bonus to anyone's tool kit.
    May 2012
    1,264
    28
    Re: "Nuts"
    Quote Originally Posted by The Viking View Post
    Thank you Viking, I'll give em a bell.
    Rob
    May 2012
    1,264
    28
    Re: "Nuts"
    Hi Rob.
    With no Issues.
    Cheers Griz, I forgot about hydraulic fittings, I have
    even used them in the past. Stainless would be fantastic
    but steel would be aceptable.
    Rob
    Sep 2003
    ISRAEL
    66
    4,119
    38
    Re: "Nuts"
    They might have an agent in the UK,
    http://www.ham-let.com/cat.php?g=6
    Somerset
    63
    4,529
    38
    Re: "Nuts"
    Hi Chemi.
    An interesting website posted.
    The Tee's shown are the JIC ones that I mention in my post.
    You can see the flare is a sharper angle and there are less turns to the thread.
    But they work fine all the same.
    Most know what you mean when you refer to JIC fittings
    May 2012
    1,264
    28
    Re: "Nuts"
    Cheers guys. I'll do some looking around.
    Griz, I have been told that the newer concentric 410 flare block
    has a slightly different angle than the older traditional flare block.
    The new flares do adapt to the older shape so i'd imagine the steel
    ones with a slightly different angle would be very similar.
    Rob
    Sep 2003
    ISRAEL
    66
    4,119
    38
    Re: "Nuts"
    Hi Chemi.
    We use their parts for CO2, Oxygen and Nitrogen connections and control instruments up to 300bar.
    Auckland
    67
    3,362
    31
    Re: "Nuts"
    swagelok have range of flare / male and female fittings.
    May 2012
    1,264
    28
    Re: "Nuts"
    Oooh I'll have a look
    Thanks Rob
