    Oct 2016
    Palestine
    45
    2
    Condenser minimum Static Pressure
    Hi very body
    I have (NH3) EVAPCO LSCB-460 with heat rejection 1980 KW condenser and would like to replace the depreciated fans by another centrifugal fans with almost similar air flow and power but need to confirm the value of minimum static pressure that the fan can be selected with
    70
    10,627
    52
    Re: Condenser minimum Static Pressure
    Can you measure the present pressure or has the fan already failed?
    Oct 2016
    Palestine
    45
    2
    thanx Mr. Brain_UK for your response.
    Unfortunately the fan failed and I couldn't do measurements.
    So I need some one based on his experience to tell me , such condenser, how much must be the static/total pressure for the replacements centrifugal fan with similar power and air flow
    I thought a fan with total pressure > 800 Pa may be accepted but I need a confirmation from someone know well about.
