    Jan 2015
    United Kingdom
    64
    36
    mitsubishi heavy industry
    hi all,i have 1x mitsi heavy ind outdoor model fdc200vs on r410a gas 3x indoor cassettes model
    fdt71wf.when switched to test run on heat/cool units run breifly then controller screen (fixed type) goes blank.It switches back on then does the same.the controller led flashes red continously.
    it works if units are set to fan only.i have not tested any further because of heavy rain.
    Has anyone any ideas,i thought it maybe held off by a bms system,but then as stated it stays
    on if units are on fan only,also units do heat or cool for a short time if outdoor unit is switched
    off/on again,no fault codes showing on controller.
    thanks doorswing.
    Oct 2007
    manchester
    5,639
    45
    Re: mitsubishi heavy industry
    bit rusty on mhi- have you addressed the 1 with the remote as master then the 2 others 01 02?- remote connects to all indoors i think
    Jan 2015
    United Kingdom
    64
    36
    i will check when i go back to site next week,thanks install monkey
