Results 1 to 9 of 9
    TBFTL's Avatar
    TBFTL Guest
    Titanium Flat Plate Heat Exchangers
    Need a bit of help if possible.
    I'm trying to find manufacturers of the above type of heat exchanger.
    I know Tranter manufactuer a plate coil but does anyone else.
    It needs to be Titanium because it is a sea water application.
    Aug 2005
    5,302
    Mar 2006
    dallas, texas
    75
    108
    Re: Titanium Flat Plate Heat Exchangers
    MY old company is one of the best with titanium and sea water applications they also use a non titanium material that is less expensive .
    Contact Zahid Ayub @ Isotherm in the USA
    I think he likes to use isoflx1@aol.com
    Oct 2003
    5,630
    34
    Swep, AIA in Sweden,
    Jun 2006
    SPAIN
    49
    13
    Arrow Re: Titanium Flat Plate Heat Exchangers
    I agree you should contact the guys at ISO-THERM.
    www.iso-therm.com
    Roar Ellefsen's Avatar
    Roar Ellefsen Guest
    Wink Re: Titanium Flat Plate Heat Exchangers
    Teknotherm Inc. manufacture shell and tube flooded heatexchangers with titanium tubes, stainless 316L tube sheets and stainless bwater boxes. Teknotherm also make DX- shell and tube with titanium tubes, stainless tube sheets and stainless shell.
    Roar Ellefsen
    Quote Originally Posted by TBFTL View Post
    Roar Ellefsen Guest
    Roar Ellefsen
    Sep 2006
    Mindanao, Phils.
    257
    Hope you could have one immediately.
    My supplier Alfa Laval Phils. needs lead time of up to 6 months for Titanium Plate Heat Exchangers.
    A lot of my customer use it for boat refrigeration, Evaporators as well as Condensers.
    Also, thre are no small ones for a PHE with titanium plates.
    What capacity do yo need?
    What refrigerant do you intend to use?
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    I confirm alva laval is having 6 months delivery time on these goods
  1. Howto: Calculate coaxial heat exchangers
    By JKProSoft in forum Technical Speculations
    Last Post: 10-01-2011, 12:10 PM
  2. Refrigerant to water heat exchangers
    By sunwind in forum Technical Discussions
    Last Post: 24-06-2008, 01:40 PM
  3. frostles heat pump
  4. Poor Heat Exchangers
    By alireza in forum Trouble Shooting
    Last Post: 21-03-2007, 08:51 PM
  5. Eroding in pipe heat exchangers
    By Carlo Hansen in forum Fundamentals
    Last Post: 10-04-2005, 08:34 PM
