    Sep 2016
    UAE
    2
    propylene refrigerant criteria
    If we use propylene as refrigerant in the screw compressor,is there any criteria of the propylene refrigerant?If some chemical plant can provide propylene which purity is up to 95%,can I use the propylene as refrigerant?
    May 2012
    1,264
    28
    Re: propylene refrigerant criteria
    See
    http://www.boconline.co.uk/en/produc...e45-r1270.html
    It is flammable
    so be very carefull on how you use it.
    Rob
    Sep 2016
    UAE
    2
    Propylene is used as refrigerant. I want to know the purity level and its effects.
    69
    10,504
    It should be 100% pure.....
    https://www.google.co.uk/url?sa=t&so...jelyRof3N6yxxA
    Data sheet ^
    Oct 2007
    sweden
    93
    14
    If major impurity in propylene blend are propane (R290), 5% propane in propylene blend make small amount of glide - around 0.033 degree C ( 1MPa pressure and 19.48 degree C) and have none effect in practical use.
    if dominate impurity are Ethane - it make more glide, much more than propane. In 1 MPa pressure, 5% ethane in propylene, dew-point 17.03 degree C and bubble point 13.23 degree C.
    if you have choice, and don't can get pure >= 99.5% propylene, select propylene with propane as impurity before alternative propylene with methane as impurity
    some welder fuel/MAP-gas have 99.5 % Propylene inside and 0.5% impurity in this blend are propane in most case
    May 2012
    1,264
    28
    Quote Originally Posted by Zuxwill View Post
    Did you look at the link I posted?
    If you did your question would be answered.
    Rob
