Results 1 to 9 of 9
    Sep 2016
    Brazil
    27
    Question Wet bulb temperature
    Hi every one...
    I am new in this forum, I am a industrial refrigerantion engineer in Brazil since 2008.
    Right now, I need some help to find an equation or software or anything else to calculate wet bulb temperature from dry temperature and humity...
    Thanks!
    Renata
    Jan 2006
    Croatia
    63
    2,136
    Re: Wet bulb temperature
    Hi, Renata
    welcome to RE forums...
    Quote Originally Posted by Renata View Post
    Hi every one...
    Thanks!
    Renata
    maybe this will be of some help ... the last one is not bad ... enjoy ....
    http://www.srh.noaa.gov/epz/?n=wxcalc_rh
    https://www.easycalculation.com/weat...calculator.php
    http://www.daikin.be/en/support-and-...are-downloads/
    http://www.daikin.be/en/binaries/Psy...505-229283.zip
    Best regards, Josip
    Mar 2010
    Lisbon
    55
    11
    Hi Renata,
    I use a formula from a study of Roland Stull - University of British Columbia, Vancouver, that gives an approximative value good enought for me. It is valid from -20ºC and +50ºC except for situations both with low humidity and temperature. You can try it:
    T.BH = T.Seca *ATAN(0,151977*(HR +8,313659)^(1/2))+ATAN(T.Seca +HR )-ATAN(HR -1,676331)+0,00391838*(HR )^(3/2)*ATAN(0,023101*HR )-4,686035
    There are others more simple but with worst results.
    Best regards,
    Carlos Duque
    Dec 2008
    Portugal
    42
    1,040
    13
    Hi Renata,
    You can use the psychrometric chart. You get the point for the dry bulb temperature and relative humidity you have and then you follow the line with constant enthalpy (the evaluation is aproximately an adiabatic/constant enthalpy) and you get the wet bulb temperature on the saturation temperature of the air on the limit curvy line, at 100% relative humidity.
    Mar 2010
    Lisbon
    55
    11
    You can also use one of the many Psychro applications existing for PC, IOS or Android.
    For example for PC you can try:
    https://www.munters.com/en/specific-...tric-software/
    Sep 2016
    Brazil
    27
    Thanks a lot!
    Sep 2016
    Brazil
    27
    cduque,
    It will help me a lot, thank you very much.
    Sep 2016
    Brazil
    27
    Thanks, Sandro, but I was looking for an automatic method, because I will use in a excel sheet with many data points.
    Dec 2008
    Portugal
    42
    1,040
    13
    Ok. I see.
    "Já agora, bem vinda ao forum da refrigeração. De que zona do Brasil és?"
Tags for this Thread
