    Sep 2016
    serbia
    28
    10
    MYCOM compressor N6B and FM160L-M manual
    Hello,I am new on this forum.
    I just start to work in meat industry as a operator for cooling system,I had no previous experience.
    They have old MYCOM compressor N6B and screw compressor FM160L-M.
    I have not found manual for this compressor.
    These two links :
    http://www.mayekawausa.com/techdata/index.html
    http://www.mycomcanada.com/downloads/ManualsDL.html
    have instructions for newer compressor.
    Where to find manual or manual for similar compressor.
    Sorry for bad English.
    Mar 2010
    Lisbon
    55
    11
    Re: MYCOM compressor N6B and FM160L-M manual
    Hi bato87,
    I have manuals of those kind of compressors in pdf format, if you send me an email adress I can send you. When you say N6B I imagine you refer to N6WB, right?
    Sep 2016
    serbia
    28
    10
    Quote Originally Posted by cduque View Post
    Hi bato87,
    They have N6B,I don't now is N6B similar with N6WB,I think they are similar.I found manual for N6WB.
    Can you send me manual for FM160L-M?My email is batop87@gmail.com.
    Sep 2016
    serbia
    28
    10
    Hi bato87,
    2,565
    28
    This should get you out of trouble!
    http://www.hosbv.com/data/specificat...m%20160M-M.pdf
    Sep 2016
    serbia
    28
    10
    Thank you!!!!!!!!!!!
    2,565
    28
    Quote Originally Posted by bato87 View Post
    Bato87,
    Main difference is valve springs & plate,
    - WB use heavier springs which are not interchangeable, as won't clip into valve plate.
    - water cooled heads on "B" have water jacket cast into head.
    - Shaft seal is single type in "B" & double "WB", but interchangeable.
    That"s about it.
