    Apr 2008
    Southampton, England
    43
    895
    27
    Thermostat Terminology
    Had to prat about looking for a chest freezer thermostat.
    Question I have is came across this from Mr Tonoto:
    Thermostat guide:
    Fridge Thermostat: Ranco VF3,VL3: Universal
    Ranco:
    UNIVERSAL
    Freezer/Ice cream cabinet: 'No signal'
    Cold out -34c, Warm out -16.5c, Warm in -12c, capillary length 2000mm:
    Fridge Thermostat: Ranco VS5,VL5: Universal
    Ranco: Compares to Atea W6, Danfoss Kit 6 and Whirlpool WPLW6
    UNIVERSAL
    Freezers with signal:
    Cold out -34c, Warm out -16.5c, Warm in -12c. Signal operation cuts in 5c above cut in. Capillary length 2000mm
    What is meant by signal or no signal?
    Situation is electronic version broken on a Walls Ice Cream chest freezer so just want to use a mechanical one. Could be a VF3 or a VS5, only difference is the signal bit.
    Thanks,
    Andy.
    Auckland
    67
    3,362
    31
    Re: Thermostat Terminology
    Signal is for alarm output
    Jul 2010
    NTH.QLD Australia
    55
    1,755
    26
    A VF3 is a basic mechanical thermostat for Freezers that have static coils. As in domestic and lite commercial chest Freezers.
    A small tube has been run inside the cabinet for thermostat capillary placement.
    May 2012
    1,249
    28
    As stated,
    Signal is red light warning at 5C above cut in.
    Does not have to be used if no warning light is used on the freezer.
    Rob
    Aug 2014
    69
    410
    Hi Andy
    just to clarify the domestic thermostat terminology a little further.
    All of the stat manufacturers such as Ranco, Danfoss,Atea,Penn,GE etc make thousands of different thermostats for the different cabinet manufacturers. These stats all have slight differences to satisfy these OEM's demands. So they also make a small range of Service kits that can replace most of the OEM specials to help the service industry.
    Danfoss have 8 service kits .
    For a Fridge Freezer with auto defrost use KIT No 3
    For an ICE Cream Cabinet / Freezer without signal use Kit No 5
    For a Freezer with Active signal use Kit No 6 (Signal light comes ON with a rise temperature )
    For a Freezer with Passive signal use Kit No 7 (Signal light goes OFF with a rise in temperature )
    For a refrigerator use Kit No 1
    It all depends on the preference of the cabinet manufacturer which type is fitted from the factory but all will control the temperature . The Signal Alarm Light or Buzzer is a nice to have feature .
    All the stat manufacturers have their own similar ranges . Your local wholesaler should be able to give you a cross reference list of these stats to make our life less stress free
    Ps when the charge in the capillary tube has been lost some types failsafe some fail open circuit
    Br Glenn
    Ps if you cant get a cross reference list let me know
    Apr 2008
    43
    895
    27
    Thanks everyone for the replies.
    New one turned up today so no excuses. Varifix VL3 for reference.
    Also out of interest found this with some photos of the old factory (but can't find the link to the catalogue I had a few days ago which might be of more use). Interesting to see they had a Miss Ranco competition. Perhaps they should have followed it up with a calendar.
    http://www.plymouthherald.co.uk/pict...ictures.html#1
    Thanks again!
    Andy.
