Thread: johns-spanner
    Aug 2016
    United Kingdom
    3
    johns-spanner
    have mitsubishi PFFY-P40VLEM-E require the plug for CN31 PCB connector (drain overflow) any ideas, not a mitsubishi part?
    11,192
    Re: johns-spanner
    If it isn't a Mitsi part then what do Mitsi normally fit there?
    Apr 2008
    Southampton, England
    49
    1,045
    35
    Re: johns-spanner
    Is this for when you fit a separate pump to a floor unit?
    Never fitted one but would have thought it comes with the Mitsi pump.
    Failing that use an aftermarket pump with a reservoir.
    Cheers,
    Andy.
    Aug 2016
    United Kingdom
    3
    Re: johns-spanner
    this plug has a wire in a loop, if fitting a remote pump you cut into the loop and connect wires to the overflow sensor on the pump. this plug is part of the Mits unit but they claim the plug is not on there part list?
    awaiting info from factory, in hope.
    Dec 2005
    Cheshire
    264
    21
    Re: johns-spanner
    I've asked for this before - part number should be 231065.
    However, from memory, the part just arrived the same as the plug with the loop, so I had to cut this and carefully solder 2x tails to allow connection to the condensate pump wires.
    edit: just realised the above was on a PEFY-P140VMH
    Aug 2016
    United Kingdom
    3
    Re: johns-spanner
    thanks anyway will try part number with Mits.
