    Mar 2012
    Canada
    2
    Heat reclaim capacity and CFM
    Hi everyone,
    I’m working on the design of a supermarket refrigeration system, and I have some questions about heat reclaim capacity, flow rate and air velocity.
    1- How can I calculate the heat capacity required of a 10000 ft2 area (One section of the store)
    2- How can I calculate the flow rate of air fresh and recirculated air in this area?
    3- How can I determinate the velocity of air?
    Refrigeration data:
    MT compressors capacity: 800 000 Btuh
    BT Compressors Capacity: 260 000 Btuh
    Refrigerant: R404A
    Ambient design temperature: 105 F
    Thank you in advance!
    11,025
    Re: Heat reclaim capacity and CFM
    If you are having to ask these questions then I would suggest that you should not be 'designing' such a system. You should be studying.
    Mar 2012
    Canada
    2
    Hi Brian,
    Thank you for your answer.
    Of course, I' m designing refrigeration system and asking about HVAC.
    Have you an answer for my question?
