Results 1 to 2 of 2
    Aug 2016
    Uk
    37
    23
    Vhac filter access points?
    Hi all
    I have had a callout because a vhac is leaking through the sides where the belly pan is situated. Im pretty sure this is due to blocked filters. My problem is design, the access points are at
    The sides of the unit and are tightly hung between two walls 🙄. Is it possible to remove the filters through the bottom of the units if i remove the panels?
    I need a heads up, as i will have to arrange for ceiling grid to be removed.
    Aug 2016
    Uk
    37
    23
    Re: Vhac filter access points?
    All sorted, thanks
