Results 1 to 34 of 34
Thread: Evaporator heating up
Threaded View
15-08-2016, 12:58 AM #12
Re: Evaporator heating up
I have tried pressures as high as 3psi and see similar warming but I can't then keep the box as cold as I need to. 4psi would be about neg 5 deg F. Not sure if that would be cold enough but I can try. WOULD a short charge cause the same sort of starving and would that starving cause the heating we are seeing?
