    Nov 2008
    nepal
    125
    Is it Possible to Disable the drain pump of Ductable Unit.?
    Greetings of the day.!!
    is it possible to disable the drain pump on Mitsubishi VRF duct-able units model no:PEFY-P VMA(L)-E.and
    can we used manually port for drain.if possible then how would we do.waiting for positive reply.
    Re: Is it Possible to Disable the drain pump of Ductable Unit.?
    You should be able to if the manual drain socket is fitted to the unit.
    Leave the pump in place but remove it's power supply from the control PCB.
    Technical/service manual here...
    http://planetaklimata.com.ua/instr/M...Manual_Eng.pdf
    Nov 2008
    nepal
    125
    ok Brain i will do as per your instruction.
