05-08-2016, 04:08 PM #1
Evaporation tray no longer attached! Help!
Hi!
My Indesit domestic fridge has an evaporation tray at the back on the top of a warm part (sorry, don't know the name of that bit). The silicon or whatever is stuck to the metal warm bit but the plastic tray has come loose and so when it gets filled with water from the fridge, overbalances and spills onto the floor.
How can I reattach the plastic tray to the warm bit so the heat can transfer and evaporate the water again?
Help!
FridgeID of Lancashire
05-08-2016, 08:41 PM #2
Re: Evaporation tray no longer attached! Help!
Stick it back with some silicone sealant.
That black hot thing is the compressor.Brian - Newton Abbot, Devon, UK
05-08-2016, 09:23 PM #3
Ah-ha! Thank you so much Brian, can I just use any?
06-08-2016, 10:33 AM #4
@fridgeID as the compressor is hot so go for HT300, Weicon brand silicon. As this is for high temperature operation so will withstand at those temp. and will hold the tray in place too.
image.jpgI maintain, everything I have, myself.
