    Apr 2007
    42
    29
    Hoshizaki IM-45LE
    I have the above ice machine that will no produce any ice.
    I have replaced the cube sensor and also recharged the system as nameplate
    This is what is happening
    On turning the unit on water fills the cube tray and and over fills it then the compressor kicks in the cube tray frosts up for approx 15 minutes. Hot gas defrost comes on the tray motors down and a flood of water no ice!
    Any advice would be much appreciated
    Apr 2007
    42
    29
    Re: Hoshizaki IM-45LE
    Does anybody have any experience with this ice machine?
    Sep 2009
    Cyprus
    77
    63
    Apr 2007
    42
    29
    Thanks, I already have the manual I've not really had much time with this ice machine and was looking to be pointed in the right direction with it
    Apr 2007
    42
    29
    Thought I would post an update. I have fixed the unit now that I spent a little more time looking at the problem.
    I found that there was a loose wire on the spay pump.
    11,025
    Thanks for the update and glad that you've solved the problem.
