    Jun 2016
    Egypt
    30
    3
    How to calculate the mass flow rate ?
    Hello all, I don't know if it's the right place to post this but forgive me if it's not.
    I need to calculate the mass flow rate of a glycol circulated around a mold Project 2.jpg
    The load in the solidification cell is 92000 Joule, I want to get it to -15°C in about 30 Minutes so I think I will need to get the inlet temperature of glycol to -20°C.
    what I am thinking about is that:
    Capacity=Load/Time=92000/(30*60)=52 Watt
    Capacity=M.*Cp*(Tout-Tin)
    If that is true then I have two unknowns mass flow rate and the output temperature then how to calculate the mass flow rate to get the right pump?
    Correct me if I am wrong.
    Jun 2016
    the Netherlands
    2
    Re: How to calculate the mass flow rate ?
    You could calculate it emperically. Tune the flow until you detect an outlet temperature of -15. Only possible of course if you have a practical setup.
