Results 1 to 2 of 2
    Jun 2016
    AUSTRALIA
    1
    Daikin BRC1C51/61 ducted a/c
    I have Daikin ducted system. Outside unit is running fine, when i turn the switch on system runs for a couple of minutes than stays idle. Error code E03 showing funny thing is tech came over and said pcb and motor fan is not functioning. I was playing around with wall mount controller and tried to reset, does anyone know how to master reset.
    Dec 2008
    564
    Re: Daikin BRC1C51/61 ducted a/c
    Power off the condensing unit. Possibly press the test button once and then press and hold the On/Off button down the On/Off button for about 5 sec.
    If the fault code clears, then the unit might run for a period before finding the same fault.
    Bedford. Now retired and trying to relax.
