Results 1 to 8 of 8
    Jun 2016
    United States
    4
    R22 low subcooling
    r22 2 ton goodman no txv. outside air temp 90.31 deg. split temp air intake and best register.low side 67, high side 218. superheat 18 subcooling 1.3. tech came out said system has noncondensables. want to recover *****,clean evap coils and pull vacuum. recharge. r22 is very expensive, could he just pump down,clean coils, vacuum and recharge?
    11,025
    Re: R22 low subcooling
    It depends, what is the legal stance were you are with regards to using R22 as it is now a banned refrigerant.
    Other than that, if the refrigerant has non-condensibles then it can be cleaned but that costs money also.
    Jun 2016
    United States
    4
    still have here in texas. 450 dollars 30 lb bottle.
    Jun 2016
    United States
    4
    tech came. recovered my ***** to clean bottle.cleaned evap and cond coils. checked amps on fans. all good. vacuumed sytem. added ***** back. charged me for 1 lb. new numbers are inside wet bulb 60f. outside dry bulb 84. low press 70 high press 178. SH 1.6...SC 4.7... target SH 8.6 on feildpeice. he said im good and left. 625 dollars. hope it works. feedback please.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by dwsmith43 View Post
    Multiply your $ 450 USD by 5 and convert to OZ $. R22 here is close to the phase out stage.
    Last edited by mikeref; 22-06-2016 at 09:02 AM. Reason: Currently one AU $ is 75 Cents Merican
    Apr 2001
    79
    5,071
    35
    According to these numbers, the SCT is 10F over outdoor ambient with low superheat. Maybe I'm wrong or maybe the numbers are wrong, but this doesn't look good.
    Jun 2016
    United States
    4
    your right about that. 86 degrees in the house. 88 outside. on the upside, less humidity in here.
    Apr 2001
    79
    5,071
    35
    I would remove refrigerant very slowly until the superheat is at least 10F... and hope the valves are not broken.
