Results 1 to 50 of 72
Threaded View
10-05-2006, 06:46 AM #11
Re: crazy 3rd-world idea: aircon from small fridge
Originally Posted by herefishy
Make some holes and insert copper pipes in it and circulate on it with a pump through a coil.
This will work better then a fridghe (which will never work)
You asked: what will be the effect with the fridge...well...temperature in teh room will perhaps drop from 35°C(95°F) to 34.7°C (94.5°F)
Does it cool?
But, you will feel some cold coming out the fridge but the effect on the room will be zero. And I think it even won't drop, it will only dry a little bit.
First thing you have to do if you only have a small capacity available is isolate the place very, very good.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
