Results 1 to 12 of 12
09-06-2016, 03:14 PM #1
Air Conditioning unit making loud buzzing sound? Video attached
Was using my air conditioning unit when all of a sudden it started making a loud buzzing noise.
I turned it off for 20 minutes and turned it back on and the noise continued.
After 30 minutes of having it on with this noise it still works fine, cold air coming out perfectly.
Even when switched onto the fan only mode , when the compressor is off etc.. it still makes the noise.
Any ideas on what it could be or what to do.
Help would be greatly appreciated!
Thanks, video attached.
09-06-2016, 05:43 PM #2
Re: Air Conditioning unit making loud buzzing sound? Video attached
Check to see if something has fallen into the fan, maybe got in via the flex duct. Difficult to tell what it is as the audio makes it sound more like a growly compressor.
09-06-2016, 10:35 PM #3
Compressor failing!!
11-06-2016, 12:28 AM #4
No. OP said he was running fan-only and still making the noise.
Relates to the fan/fan motor.
28-07-2016, 11:45 AM #5
We need to see a video with it with fan off as that loud noise in the video is definitely the compressor.
29-10-2016, 11:00 AM #6
Whilst it sounds like the compressor, the noise is still present during fan-only, so have to exclude the compressor.
Noise has to do with the fan.... maybe capacitor or fan motor or fan bearing problems?
22-12-2016, 10:01 AM #7
If your air conditioner is making loud buzzing sound, then might be your air conditioner is facing issues of compressor malfunctioning, frozen AC unit. Another reason could be loose air conditioner parts.
23-12-2016, 08:09 AM #8
06-01-2017, 04:21 AM #9
No,the video attached is not working.
06-01-2017, 05:22 AM #10
Hi Mike
Original post was 6 months ago I think jordanoye may have had it fixed by now. When I opened the video it said it does not exist so probably wouldn't worry about it.
PaulBorn to fish, forced to work
06-01-2017, 07:31 AM #11
Ta Paul. Been here for several years so one would think checking op's time of posting would be standard practice by now....
Teacher in Primary school said i would forget my Head if it weren't screwed on.To the optimist, the glass is half full. To the pessimist, the glass is half empty.
19-04-2017, 06:30 AM #12
Better you open all your air conditioner and then check inside air conditioning that what is happening. May be one pane broken inside and that creates noise.If the coil fins have become clogged with dirt, the air conditioning in glasgow unit may become noisy.You may prevent the occurrence of noise by oiling the air conditioner motor at the beginning of each summer.
