    Jun 2016
    saudi arabia
    1
    thermoking/MD200
    hello everybody.my name is Nelson,i have problem in Thermoking MD200.the low pressure is 20psi & high pressure is 350psi (R404a) but the box Temp.is only 15*c ..can you give me an idea what is totally problem..temperature must be -18*c...thank you guys.
    Melbourne
    347
    Re: thermoking/MD200
    how big is the box ? Have you tried it with a at temp load ?
    -18 from a MD200 in high ambient could be a big ask
    The pressures sound normal for your ambient
    Aug 2011
    Canada
    160
    15
    20 psi suction is the CPR setting.
    What is the temperature difference?
    Is the three way sealing?
    Is it flooding?
    Is the ball up?
    Is the condenser clean?
