Results 1 to 10 of 10
    Feb 2012
    libya
    41
    94
    13
    ammonia leakage ventilation
    Dear Sir
    we have production room with dimensions 40m*40m*5m and sometimes we face ammonia leakage so please how we make ventilation in short time. your suggestion & ideas highly appreciated
    Thank you
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: ammonia leakage ventilation
    Hi, mre212,
    this can be quite dangerous sometimes ....
    Quote Originally Posted by mre212 View Post
    Dear Sir
    Thank you
    it is not easy to suggest anything like ... do this or do that ... because we do not know anything about your production area ... what kind of equipment you have installed inside and where are the most possible leak positions ...
    maybe some aerial view of your production area with position of equipment ...
    Generally, you need to install inlet and exhaust fan ... but where, it is not easy to tell you now ... need some more info if available ...
    Best regards, Josip
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Design your extraction and air change rate for a high turn over rate activated via high level detection sensors.
    A good idea is to keep some trickle ventilation in place with fire alarm shut down of course.
    I did design a high velocity ventilation system for a client where we used a water misting spray ring incorporated into the fan output nozzle ring to act as a knock down. As the ventilation fans had the potential to discharge into an occupied area.
    Feb 2012
    libya
    41
    94
    13
    we are ice cream factory and we use ammonia for ice cream continuous freezer and hardening tunnel... etc. sometimes we face ammonia leakage and we like to remove the smell in short time
    Thank you
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, mre212
    Thank you
    To be honest, I am surprised with kind of leaks you faced from time to time ... it is not usual ... maybe question of good service i.e. maintenance .... I know managers are looking to have a good and big production, but you must not forget safety ... it is easy to hurt some operators and then ...
    anyhow the best is to do some kind of ventilation as described by hookster ... you know where will be the best position for inlet and outlet fans ... to run in auto mode by some ammonia sensor (nowadays it is easy to provide some good and not too expensive) or to start it manually ...
    Best regards, Josip
    Feb 2012
    libya
    41
    94
    13
    Please do you have manual about best practice for ammonia extraction system from production area
    Thank you
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, mre212
    Thank you
    unfortunately I do not have any manual about - this matter is mostly quite specific - of course we need to follow some rules ... type of fans ... extraction capacity ... etc ...
    ... but I hope some member will come with some good advice...link ... whatever to help you ... here are some links where you can found something useful ...
    also you can search by yourself for some good solution for your ventilation system ...
    http://www.cdc.gov/niosh/docs/81-123/pdfs/0028-rev.pdf
    http://www.condorearth.com/files/05-...er_Redding.pdf
    http://retaaz.com/retaazphx/library/...0Standards.pdf
    https://www.google.hr/url?sa=t&rct=j...DiJjqStcD26Pvg
    http://www.agcs.allianz.com/assets/P...ms%20FINAL.pdf
    http://www.ozoneprogram.ru/upload/fi...egulations.pdf
    https://www.epa.gov/sites/production...on_5-20-15.pdf
    https://www.osha.gov/SLTC/etools/amm...on/references/
    Hope this will be of some help to you.
    Best regards, Josip
    Auckland
    74
    3,357
    37
    Your extract fans should be X rated ( explosion proof ) and starter equipment located outside / away from hazard area. Two levels of ammonia detection, inter connected to fire alarm evacuation system. Air extract flow rate dependent on interior space volume, your local regulations will stipulate air volume changes per minute. In addition all electrical supplies to effected area will be automatically isolated remotely with shunt trips to supply circuit breakers activated by ammonia alarm system.
    Feb 2012
    libya
    41
    94
    13
    kindly the air extract flow rate depend on interior space volume of production room or Lbs of refrigerant(NH3) in system?
    shall we install AHU for fresh air or Wall Louver is OK?
    what is the recommended pressure for production room and how we obtain that?
    Feb 2012
    libya
    41
    94
    13
    Is it ok to install a fan to extract air (composed of ammonia) without fan to intake fresh air ?
    waiting for your reply. Thanks a lot
