Thread: Wireless gauges
    Nov 2011
    Kent
    4
    Wireless gauges
    I have a yellow jacket mantooth and I this will be a stupid question but high temp pipe clamp, where dose it go on the discharge of the compressor or the liquid line.
    Feb 2007
    2,477
    Re: Wireless gauges
    It all depends on what you want to measure.
    - If its on the discharge you will get the discharge superheat.
    - If it is on the liquid line you will get the sub cooling.
    I believe the default for the YJ app is sub cooling, so if that is what you want to see then liquid line it is.
    Nov 2011
    Kent
    4
    Re: Wireless gauges
    Ok thanks, I was looking at the testo smart probes as they are all wireless
    Feb 2007
    2,477
    Re: Wireless gauges
    Quote Originally Posted by Shussey1 View Post
    I have a yellow jacket mantooth.
    However, same principle applies...
    Nov 2011
    Kent
    4
    Re: Wireless gauges
    I find the interconnecting cable between the two pressure sensor too short and some times hard to fit
