    May 2016
    morocco
    38
    2
    Red face CAREL, MCQUAY, TRANE Controller reparing !
    Hello,
    What do you think about reparing CAREL controllers ? is it required by some one ?
    I think that it cost lowest than bouth a new one !
    Regards.
    May 2016
    morocco
    38
    2
    Re: CAREL, MCQUAY, TRANE Controller reparing !
    We succed to repaire more than 10 CAREL contollers by replacing the main board .
    Oct 2012
    Russia
    36
    391
    12
    Chipper buy from e-bay and load firmwire.
    May 2016
    SPAIN
    35
    32
    My 2 cents:
    Of course it depends on the type of failure. I have been working for the HVAC industry programming CAREL controllers. What I can tell you is that PCOx family is not expensive if you compare with other brands. If the problem is software, as Rusbuka said, you can load firmware by using the PCOLoad tool. However, if the problem is hardware you will have to change the component that is not working properly, sometimes that is difficult to identify and the simplest (not cheapest) way is to change the board.
