    Nov 2008
    canada
    56
    10
    Engine room Exhaust fan
    Is there a test I can do to verify the CFM on my engine room fans?
    Feb 2009
    telford
    2,009
    27
    Re: Engine room Exhaust fan
    Who makes the fan,maybe they would have the info guess speed size and some others factors may be needed there is the old saying my retired fridge tech used to say it will only blow what it can suck!
    Feb 2007
    2,477
    Yes,
    Using an anemometer you get the velocity of the air in the duct (or, if ductless, you have to make a funnel like hood out of cardboard or MDF to channel the air through) then you just multiply the velocity with the area of the duct (or opening of your funnel) and you have your CFM.
    For example, if air is moving at 1 ft/s through a 1 square foot hole then you are moving 60 CFM (1 x 1 x 60=60)
