Thread: Mark957
    Somerset
    69
    4,698
    Mark957
    Re: Blue Box Chiller = Stumped! (UK Slang for confused)
    Hi GrizzlyWhen you experience high pressure alarms from digital input is not caused by high pressure then the input is acquired properly.
    is the case here in the controller Carel PCO2 has input defective.
    to overcome the problem queso Carel provides a service kit j8.
    contains two capacitors to be mounted between terminals ID13H-ID13.
    And ID14H-ID14.
    This change allows you to bypass capacitors inside the inputs.
    hello
    Mark, if you are still with us, do you know where I could get the mentioned capacitors?
    Thanks Grizzly
    Apr 2009
    israel
    778
    Re: Mark957
    Mail.me ill explain what to do.
    U dont need capacitors .a small rewiring will do it.
    Best regards
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
    Apr 2009
    israel
    778
    Re: Mark957
    check your mail.
