Results 1 to 2 of 2
    Mar 2016
    Lithuania
    2
    Compressor cooling capacity
    Compressor manufacturers provide data like mechanical power and cooling capacity. Does anyone know, how they calculate that cooling capacity? I mean it is obvious that cooling capacity will depend on temperatures of suction and discharge sides, thus maybe there are any standard temperatures for calculating this.
    Jan 2006
    Croatia
    2,136
    Re: Compressor cooling capacity
    Hi, mankam
    welcome to RE forums ....
    Quote Originally Posted by mankam View Post
    This is easy and complicate to explain because we do not know anything about you ... where to start with explanation .....
    it will be good if you make one post here .... http://www.refrigeration-engineer.co...p?72-New-to-RE to introduce yourself to us ...
    But let's try to help you ... in refrigeration all is about mass moving ... quite simple ...
    here, below are some links where you can find some answer to your question ... then come back with any question or doubt you have ...
    http://www.refrigeration-engineer.co...ht=mass+moving
    Yeah, a lot to read (but much more to be discovered by you) .... we read it before, now is your time ...
    Of course you can use search window ... right up and write what you want to find ...
    Refrigeration-Engineer.com forums Statistics:
    Threads 37,857
    Posts 287,947
    Members 74,607
    Active Members 2,536
    Hope this will be of some help to you ...
    Best regards, Josip
