19-04-2016, 03:10 PM #1
What kind of fans are used in blast chillers?
I would like to know which fans are used and where i can get them
19-04-2016, 05:25 PM #2
Re: What kind of fans are used in blast chillers?
Could be axial, try a fan supplier.
19-04-2016, 05:30 PM #3
Ziehl-abegg will be a good start
19-04-2016, 05:36 PM #4
Or 30" Plus woods fans.
The bigger the air flow the greater the duty provided the Evap is sized correctly of course>
Check out the link.
Other manufacturers are also available.
http://www.flaktwoods.co.uk/support-...documentation/
GrizzlyDespite the High Cost of Living it still remains Popular!
19-04-2016, 08:34 PM #5
Some of the cheaper cabinets use a multifit with a higher spin speed and capacitor cabs like foster use a high spin speed four pole guard mount available from all the above or abl or most wholesalers in uk in Germany pasp or wholesalers I pressume ta charlie
19-04-2016, 09:28 PM #6
Good point made Charlie, here was I thinking of Industrial Blast Chillers.
But as you eloquently point out there is a whole range of Catering sized ones!
19-04-2016, 10:22 PM #7
Ziehl Abegg are used on Zanussi cabinets:
http://www.ziehl-abegg.com/sg/en/pro.../fe2owlet-ecq/Mostly found in the southern part of this green and pleasant land.
