    Jan 2007
    India
    65
    Oil free refrigeration system
    Hi All
    I am just wondering what would happen if moisture present in the system that uses oil free compressor. Is moisture level not critical for oil free system ? If there is no oil then chances for acid formation is remote .
    Do you foresee any another implications due to moisture for HFC and HFO refrigerants when used with Oil free compressor
    3,357
    Re: Oil free refrigeration system
    Expansion valves may block up from freezing water
    Any control valves may also play up.
    Auckland
    74
    3,357
    37
    moisture in any refrigeration system is problem, irrespective of oil free what ever, chemical reactions and water freezes.
    So no short cuts with system.
    Somerset
    69
    4,697
    As My Antipidean ( is that the correct spelling Guys?) Friends state.
    Moisture in a fridge system is unwanted irrespective of a lubricated or non lubricated compressor.
    The main selling point of Turbocor and similar comps is you have no oil logging in the system.
    Which normally collects in the lowest pressurised part of the system.
    Namely the plate heat exchanger or evap. Greatly reducing the efficiency of the system.
    Therefore no oil = No Oil Logging.
    Not No Moisture!
    I would pay particular attention to how and what Oils you use.
    11,025
    Off topic - Grizzly try antipodean.
    Jan 2007
    India
    65
    Thanks guys for the information. The reason for bringing this topics is due to the debate I come across for oil free chillers . The discussion was just a strainer is sufficient and no need of filter drier to adsorb the moisture . But I was not endorsing that option; hence would like to know more detail about the moisture +refrigerant +components behavior
    Oct 2010
    Australia
    88
    15
    Look up hydrolysis of various refrigerants. It's generally not pretty for fluorocarbons.
