Thread: carrier vector 1800
11-04-2016, 08:56 PM #1
carrier vector 1800
Have a vector that says engineer reset required I'm sure if I remember correctly u could reset it on the panel can this be done or plug in job ta gents
12-04-2016, 12:05 AM #2
Re: carrier vector 1800
99 percent it's a plug in job Charlie,someone said you could do it thru the keypad which I doubt it's normally activated so drivers can only clear codes so many times to stop them screwing up an engine,I will ask my mate in oz for you.
12-04-2016, 12:54 AM #3
Hi Charlie,someone has said you maybe able to clear it without a pc,go into alarm mode then up and enter for 3to5 seconds
12-04-2016, 08:31 PM #4
Cheers will try that ta
12-04-2016, 10:50 PM #5
Code 11and12 are low oil pressure and high water temp,if these are reset three times in a two hour period technician reset is triggered,oz friends say code 21 in the inactive alarm list needs to be cleared hope this helps buddy.
