Thread: Eurofrigo c3500
    Mar 2016
    Bulgaroa
    3
    Eurofrigo c3500
    Does anyone have wiring diagram?
    Best regart.
    Feb 2009
    telford
    2,092
    33
    Re: Eurofrigo c3500
    Sorry I don't have one,but they are quite simple, relays cut out switched for high and low pressure a pressure switch to activate the condensor fan the controller is a dixell the model number is on the back of it,are you having problems with it,I have quite a few units that I look after and never had problems with the need for a diagram.
    Mar 2016
    Bulgaroa
    3
    Re: Eurofrigo c3500
    Controller is Microstat C3500_BASIC_Range_offers_great_airflow_and_power-2.jpg which, communicate with some buffer board 12596173_10205809761910695_1255369726_n.jpg . That buffer board is broken. I want to replace the controller Microstat, with controller Dixell or similar. Which one I want to connect directly to Relay Board IMG_20160326_123333.jpg. So I want to know does the Relay board have internal interlocks between sensors and relays?
    Feb 2009
    telford
    2,092
    33
    Re: Eurofrigo c3500
    You will need to rewire from the cab to unit with stronger wire,elliwell 974 12volts and rewiring at the unit,big job.
    Mar 2016
    Bulgaroa
    3
    Re: Eurofrigo c3500
    Rewiring is not problem. More difficult is to tracking wire between sensors, fans, etc and relay board. I wanted to keep relay board, but when is not possible I must replace it with a lot of relay. With wiring diagram is more easier.
    Feb 2009
    telford
    2,092
    33
    Re: Eurofrigo c3500
    There's an old mate comes on here sometimes he will have a diagram,but not seen a post from him in a long time,maybe he won the lottery or retired to the Welsh valleys!
