    Dec 2008
    77
    137
    polar zb-26 ice maker
    I have a polar ice cubes and the tray motor is continually running .taking a wire off the microswitch does nothing and the paddle motor is not running.has anybody any ideas. I was thinking pcb.
    Dec 2010
    devon
    837
    Re: polar zb-26 ice maker
    Relays stick on pcb useually fit board and sensor if bin lid left open the bin wedges against door and overloads pcb also check gauze to water pump aint blocked top of tray we only repair um when we have advised customet what a load of rubbish these machines are next month bin motor then the ice bin stat then the rotation pump then will be time to fit another pcb
    Feb 2009
    telford
    2,092
    33
    They are not a good machine,basically when they go wrong recycle them ,I won't touch them and advise my clients to spend extra and get a quality made machine.
    Dec 2008
    77
    137
    Quote Originally Posted by cadwaladr View Post
    Yes,I quite agree with you.much prefer a k20 .Unfortunately all customers seem to look at these days is price and not quality but that's Blackpool all over.Thanks again guys.
    Split Croatia
    6,151
    As I recollect, ZB 26 does not have paddle at all. It has pump for agitation. Is this same as your model?
    In these, when reduction gear in motor is damaged, symptoms are as you described.
    You can find replacement tray motor in GEV! Code is:499086
    Also, if tray is not in correct position regarding gear position, you can have same issues because of position sensor getting wrong signal. Therefore you should check that motor shaft is in correct relation to tray. It is adjustable by loosing and after correct positioning, tightening cone connection with tray.
    And yes, they are rubbish but providing me some income!
