Thread: polar zb-26 ice maker
25-03-2016, 03:05 PM #1
I have a polar ice cubes and the tray motor is continually running .taking a wire off the microswitch does nothing and the paddle motor is not running.has anybody any ideas. I was thinking pcb.
25-03-2016, 08:38 PM #2
Re: polar zb-26 ice maker
Relays stick on pcb useually fit board and sensor if bin lid left open the bin wedges against door and overloads pcb also check gauze to water pump aint blocked top of tray we only repair um when we have advised customet what a load of rubbish these machines are next month bin motor then the ice bin stat then the rotation pump then will be time to fit another pcb
25-03-2016, 11:31 PM #3
They are not a good machine,basically when they go wrong recycle them ,I won't touch them and advise my clients to spend extra and get a quality made machine.
26-03-2016, 08:54 AM #4
26-03-2016, 05:54 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
As I recollect, ZB 26 does not have paddle at all. It has pump for agitation. Is this same as your model?
In these, when reduction gear in motor is damaged, symptoms are as you described.
You can find replacement tray motor in GEV! Code is:499086
Also, if tray is not in correct position regarding gear position, you can have same issues because of position sensor getting wrong signal. Therefore you should check that motor shaft is in correct relation to tray. It is adjustable by loosing and after correct positioning, tightening cone connection with tray.
And yes, they are rubbish but providing me some income!Last edited by nike123; 26-03-2016 at 06:15 PM.
